Information Needed on 1971 L48 350 sbc internal spec's - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2008, 09:08 PM
Last journal entry: Inch each day is ok for me...lol
I figured so far from the code (cgl) it is a 4 bolt main. I need to find out the rest, ie. cam specs and piston and rod type and crank (forged or cast). It is for a chevelle or nova or camaro or monte. And is rated at 270hp. Would like some help please.
Old 06-19-2008, 09:59 PM
It's essentially the same thing as the current Goodwrench standard crate engine.
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Timing woes on SBC 350 with bigger cam. Brawler Engine 5 09-07-2007 04:33 PM
SBC Strokers - 350 vs 400 Blocks & Combos (not just 383 & 406) ez2cdave Engine 11 05-21-2007 09:34 PM
350 sbc build up help!!! dustinweaver Engine 2 07-31-2006 06:17 PM
l48 350 specs iluvdrt Engine 1 01-12-2004 06:18 PM
