Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Information On Rockers!
Old 12-02-2012, 10:31 AM
ChevroletSS ChevroletSS is offline
WOW Thats amazing. I have some dual springs I kept off of some 84 vette heads I think they were 293's but do you know if they would be good to hold onto. Also I have a cam I installed in my truck with the following specs::
IntakeExhaustAdvertised Duration262272Duration @ .050"204214Valve Lift w/ 1.5 Rocker Arms0.4200.442Valve Lift @ Cam0.2800.295Max Lift Angle107117Lobe Separation112Cam Timing @ .050" - Opens-5 ATDC44 BBDCCam Timing @ .050" - Closes29 ABDC-10 BTDC
Would it be safe to install 1.6 rockers later down the road to improve torque. I have the 193 heads which I know they are desingned for low end torque and fuel mileage and not so much for performance. But Could I squeeze a little more towing potential out of my chevy pickup by doing this.
