Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Information On Rockers!
Old 12-02-2012, 06:21 PM
1971BB427's Avatar
1971BB427 1971BB427 is offline
You may not know this, but you can't just swap out 1.5 rockers with 1.6 and not check the pushrod length to ensure proper pattern on the end of the valves. If the contact pattern is off from the wrong length pushrod and a higher ratio rocker it can cause damage to the end of the valve at the least, and possibly worse things if a keeper comes off or something else fails.
