Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Information On Rockers!
  #17 (permalink)
Old 12-03-2012, 10:44 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Be sure to check the clearance at the push rod guide hole in the cylinder head. 1.6 rockers will put the p-rod very close to- if not touching it.
You can easily make an adjustable push rod length checker from an old push rod.
Some info:
Valve Train:
Rocker arms has info on ratios and using a Lewis tool to open the push rod guide holes in the head.
Valve spring installed height
Points to check
Geometry
Adjust lifters
Cam break in
