ingersoll rand compressor pump "HELP[" - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2012, 06:42 PM
Hi ive got a 1965 ingersoll rand 20 gal compressor with a 3-4hp motor and a single stage pump. The pump itself is the original ingersoll rand and has a bunch of different numbers on it, ill get to those shortly. I want to find a rebuild kit for the pump. It takes way to long for it to build pressure. If anyone knows where i might go about finding it please help. Yes i went to there website An i searched for 2 days with no luck. here are the numbers on the pump:
MODEL# HAF5
SERIAL#34463
these other numbers are for ? this is stamped on a plate PD 5520
and the other 18962
Old 11-25-2012, 10:14 PM
Wiki Edits: 27
local shop ?
about 12 years ago I rebuilt my pump. I ask a few local garages and found a shop that did aircompressors. I took the pump in and they identified it and sold me the parts. It gets pretty cold around here, 6 months of good snow ski weather , then 6 months of poor snow ski weather. so I wrapped some heat tape that is normally used to keep water pipes from freezing around the pump and I plug it in in the winter for 3 or 4 hours whenI want to use the shop compressor. I also made some dippers for the rods, drilled the caps and X ed the cap bearing surface, Like I did to My old Flathead 4 T motor.
Ingersoll Rand type 30 compressor kobaltblue Garage - Tools 0 09-25-2012 08:24 PM
Ingersoll Rand Compressor question.... Steel Garage - Tools 2 02-20-2012 05:42 PM
Ingersoll rand Air compressor larrylwill Garage - Tools 12 07-11-2011 07:18 AM
Ingersoll Rand 231G (1/2" impact) Any Good? Ohiowaterdog Garage - Tools 24 07-07-2007 09:15 AM
Ingersoll Rand Compressor ID banjerpicker Body - Exterior 1 06-28-2004 12:12 PM
