Ingersoll Rand Compressor question.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2012, 04:40 PM
Steel's Avatar
The Ultimate Lurker;)
Tonight I was able to pick up an older Ingersoll Rand Model 242 type-30 horizontal tank compressor on the cheap, like $100 cheap.
I have to clean it up and give it a shot of paint, but it has a rebuilt pump and the tank is solid. My problem is it was missing the motor(which I couldn't have used anyways seeing it was a 3 phase motor). But here's my quandary, I found a 6 HP motor that I could use(single phase) but it is rated at 3450 rpm and the compressor originally had a 1750.
The last thing I want to do is run that pump at twice the original RPM, so does anyone know where I could pick up a double V pulley to correct my rpm to the pump?
Old 02-19-2012, 05:05 PM
Steel's Avatar
Well, I guess had I done a little more research I would have found this super nice Baldor motor that is pretty much a direct replacement for what I need.
Old 02-20-2012, 05:42 PM
You select the size pulleys to marry the compressor and motor speeds, ie. get them at their design operating speed. Usually done with the motor pulley.
Trees
Ingersoll rand Air compressor larrylwill Garage - Tools 12 07-11-2011 07:18 AM
questions about 80 gal 5hp ingersoll rand industrial compressor richie ross Garage - Tools 9 03-22-2010 08:43 AM
ingersoll rand 4000 series 7.5 hp air compressor d&c repairs it all Garage - Tools 2 11-06-2008 06:07 PM
Ingersoll Rand Compressor Recommendations daveh Garage - Tools 8 02-02-2005 02:38 PM
Ingersoll Rand Compressor ID banjerpicker Body - Exterior 1 06-28-2004 12:12 PM
