Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Initial timing
Thread: Initial timing
Old 02-18-2013, 01:23 PM
33Willys77's Avatar
33Willys77 33Willys77 is offline
You are probably not far off. Initial at 18 (as long as it starts good) is ok with a total of 36. That is a good starting point and should be able to tune the carb in fairly well. Without being able to drive or have it on a dyno, not much more you can do.
