Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Initial timing
Thread: Initial timing
Old 02-18-2013, 06:34 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Its fine where it is. thats plenty for a 224deg cam and auto trans.
34 to 36 total.
if you want to check the idle T slot exposure pull the carb off and look.
there should be slight exposure. at idle
Pri and sec should be more or less even at idle.
what is the LSA on that cam? what is the manifold vacuum at idle? in gear and in neutral.... idle rpm.
are the idle mix screws active?
