Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Initial timing
Thread: Initial timing
Old 02-19-2013, 08:03 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Originally Posted by MouseFink View Post
If you are seeing 22 degrees at idle, is is NOT the initial timing.
it is when the distributor cent curve has been modified and limited to 14deg travel.
This is not a stock distributor with a stock 20 to 24deg centr curve.
