Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Initial timing
Thread: Initial timing
  #25 (permalink)
Old 02-20-2013, 08:42 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
if the power valve is fluctuating at idle change to a 4.5". It must stay closed at idle and closed when idling in gear when manifold is lowest.
What is this 224deg .450" lift cam? A dirt track motor "lift rule cam"? Brand?
These cams usually need a 10" torque converter. And the typical "2500 stall" is not loose enough at idle.
usually a "2500 stall" is a cheap tweeked stock diameter 12"+ GM converter.
