Initial timing on Pontiac 400? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2005, 02:26 PM
The car has 400 with 3000 stall. I dont know the cam specs, but it i know it a fairly big hydraulic. Car does not have power steering or power brakes. The ignition is a mallory. I took the distribuotr out ot replace the o-ring gasket and got the timing screwed up. I did not look at the initial timing before i pulled the distributor because the battery was in the trunk. I just now set the car to 8 degrees initial timing @800 rpms. The vacuum advance is not being used. The car runs ok. What should I set the initial timing at and does the vacuum advance not being hooked up affect what the inital setting should be. I'm guessing total advance would be unchanged? thanks, joe
Old 12-06-2005, 09:01 PM
Hook up the vacuum advance ,so it will have more advance at full vacuum, all you got that way is centrifugal advance and it just comes in as rpm's increase.
Old 12-07-2005, 04:56 AM
budthespud's Avatar
Diehard Chevy Guy
Hook The Vacuum Back Up
If I were you I would hook the vacuum back up. I tried this with my 400 Pontiac and the response wasn't there. I hooked her back up and the bottom end was much better. Also If I'm not mistaken the timming was 12 degrees for a stock motor but please don't quote me on that. I've played with my timing since and I turned a few degrees till I had the response I felt was the best. I'm running a mild Crane cam with thier rockers. See my photo album to see my play toy. 74 Firebird Formula 400.
There's nothing like a sweet sounding Pontiac!!!
Pontiac 400 build firebird_red Engine 4 11-02-2009 11:05 PM
Help on a Pontiac 400 dirt track motor ridlenracing Engine 9 06-16-2007 10:26 PM
pontiac 350 vs 400 bb jjweb74 Engine 15 11-12-2004 02:30 PM
vacuum advance help batman09 Engine 14 09-09-2004 09:42 PM
pontiac 400 409guy Engine 8 05-12-2004 01:57 AM
