Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Initial Timing Question
Old 03-28-2012, 09:23 PM
400smb_s10's Avatar
400smb_s10 400smb_s10 is offline
Back Yard Junky :)
Location: Around the Corner from the middle of nowhere... Arden Ontario
motor is a 350 4 bolt with 400 heads ported and polish hei distributor and 600 cfm holley carb. Umm hope this is enough info. Im not sure what the compression ratio is. Its a stock motor other then the heads cam and carb
