Initial Timing Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2012, 04:53 PM
400smb_s10's Avatar
Back Yard Junky :)
Location: Around the Corner from the middle of nowhere... Arden Ontario
What would be a good timing number for this camshaft. Advanced and initial timing
Duration @ .050" 214 int 214 Exh
SAE duration 287 287
Lobe spread 105 115
lash Hydraulic
Valve Lift ".444 ".444
Cam Lift ".296 ".296
Any help would be greatly appreciated
Thanks
Ed
Old 03-28-2012, 07:19 PM
DoubleVision's Avatar
It's not very often we time one by the cam specs as a majority of cams like the same specs. What dictates the timing is the compression ratio.
So overall is, need more info. Whats the compression ratio? What engine? what other mods have been done? What ignition system?
Old 03-28-2012, 08:23 PM
400smb_s10's Avatar
Back Yard Junky :)
motor is a 350 4 bolt with 400 heads ported and polish hei distributor and 600 cfm holley carb. Umm hope this is enough info. Im not sure what the compression ratio is. Its a stock motor other then the heads cam and carb
Old 03-28-2012, 08:48 PM
F-BIRD'88's Avatar
Yada Yada Yada
this cam like 14 to 18deg initial 34 to 36deg max @WOT.
a max of 10 to 15deg vacuum advance added at hiway cruise part throttle
Champion RV8c or AC delco R42T plugs .035" gap.
The stock GM 400 SBC heads suck even when ported.
Find some vortecs.
Bbc,initial timing(help). runndmy Engine 1 07-26-2011 05:50 PM
Initial timing PatM Electrical 8 04-14-2010 09:36 AM
thoughts on initial timing? slate84 Engine 7 03-27-2009 07:31 AM
327 initial timing? 1 Day Engine 5 07-01-2007 07:58 PM
initial timing ? Mr. Wormy Engine 6 05-13-2007 06:07 PM
