Initial timing related to dieseling? - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 10-08-2010, 10:32 AM
Ok now I have no idea.
I went out and did a little test. I have a pcv on one valve cover, and a breathr on the other.
- First I plugged the PCV hose, pulled the breather, and put duct tape over both holes in the valve covers. At idle and at part throttle, both buldge out like there is air trying to blow the tape off.
- Second, I put the pcv valve back in the valve cover and left the tape on the other valve cover. It sucked in, trying to pull the tape in the hole.
If I were to have an internal vacuum leak, wouldn't it have been trying to pull the tape into the holes to begin with?
  #62 (permalink)
Old 10-08-2010, 11:35 AM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Okay we know that the pcv is working as it should. And you are probably right about the vacuum leak test . As for the blow by test. If you have a compression gauge with a hose , you can take the spark plug hose adapter off of the hose and hook up shop air to it . You will have to back off the rocker arms first . When you apply full shop air pressure the engine will spin a little to get the piston that you are checking to the bottom of the bore , so keep your hands clear of the fan , etc. If you have piston ring blowby , you will definitely hear it from the crankcase breather . If you have a valve problem you will hear it in the intake or exhaust depending on which it is. Check each cylinder . I would definitely do this before pulling any cylinder heads so that I would know how deep the problem is .
  #63 (permalink)
Old 10-23-2010, 12:45 AM
Okay, it is definately an internal manifold vacuum leak. I am going to have the intake milled unless anyone has a better idea. By the way, thanks again for the help folks!
  #64 (permalink)
Old 06-25-2013, 10:08 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Commercial advertising is not allowed in the forums, read the board guidelines. In the video, Art Wiese is commenting, D. Wiese congratulates him, and you, Aaron Wiese make comments as well, all from Lincoln, NE, same as the company you're promoting.
Semper Fi
Help Setting Initial Timing on Chevy V8 leejoy Engine 14 07-11-2013 12:59 PM
Low buck 355 sbc not running correctly, wanting to much timing. ForceFed86 Engine 67 04-13-2011 12:35 PM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
327 initial timing? 1 Day Engine 5 07-01-2007 07:58 PM
350 chevy timing tiresmoke55 Engine 7 01-14-2006 10:55 PM
