INLET/OUTLET ID on MOPAR fuel pump? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2013, 12:54 PM
hduff's Avatar
Fix it until it breaks
Last journal entry: Matt got a new motorcycle.
I'm looking at a MOPAR small block fuel pump and have no idea which is the inlet and which is the outlet. The engine is not in a car. Nothing is marked
This may be obvious to many of you, but I'm clueless here.
Old 08-19-2013, 02:13 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Put your finger over the orifices and see which one sucks. I would assume the nipple is the inlet, the threaded end pressure out.
Semper Fi
? on a FAST efi fuel pump # 30085 inlet fitting supercab78 Hotrodding Basics 2 04-05-2013 09:46 PM
No fuel to carb, do have fuel at pump inlet - replace? bruceg Engine 8 04-22-2010 09:41 PM
Dual Inlet Fuel Pump: One inlet capped ???? Sin7 Engine 8 07-29-2008 03:32 PM
Dual inlet/single outlet Flowmaster SUV 50 Series Muffler for AMC 304 Houman SS '70 Engine 2 12-18-2007 09:14 AM
Can a radiator set up for chevy inlet and outlet be used for a Ford engine? Kruzin Karl Engine 8 12-07-2007 12:12 PM
