inline 250 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2009, 07:55 PM
inline 250
i stumbled on this site iam injoying it.i read earlyer on perfomance on the 250 i beleave i raed they are making up to 1200 hp in the uk some place like that ive seen some pic that had turbos even a blower on it i would like alot of info on the 250.my son and i are working on a 66 chevy pickup for his gradution thanks
Old 07-12-2009, 08:57 PM
riceharvester's Avatar
The 250 is a good motor, but HP/cost you would be better of swapping to a V8.
Old 07-12-2009, 09:21 PM
Wiki Edits: 31
250's can run pretty decent.. cost a lot to go really high hp numbers.. there's a 250 Camaro I'v seen on the internet. '68 I belive, somthing like 899 hp but it's not even close to streetable, and has $$$$$$$$$$$ invested into custom parts.... but getting 300 hp out of a 250 or a 292 isn't out of the question, and that's enough to make a '66 C10 fairly quick
Old 07-13-2009, 11:30 AM
The 250 has too many structural problems, you may get 1200 hp out of one with a blower of some sort, but not without spending a fortune getting there. If you must have an I6, the 292 is a better platform to come off of, especially in the corners of the head it's less likely to bust, blowing all the coolant out when working hard.
But time for a reality check, planting a V8 in there is a lot less hassle, requiring a lot less knowledge and ability and will provide more power for a lot longer life at less money.
Don't let these esoteric inlne 6 articles fool you, they make it sound like getting a lot of power out of the Chevy, or Ford for that matter, inline 6 is pretty simple, trust me it isn't. On the other hand, doing it will teach you a lot about engines and part fabrication.
Bogie
Old 07-13-2009, 11:39 AM
Wiki Edits: 31
Bogie
I6's are anything but simple.. they are a very simple engine, but because of the lack of performance parts for them, you gotta know how to figure stuff out, theres no 'build articles' for them.. The article I wrote on Ford 144-250 I6's in the Wiki is based on my experience... no real fabrication except for the turbocharger, but I had to figure everything out, and spend hours on dyno software, choosing cams, figuring out compression ratios, boost ratios.. my whole build was calculated with matching parts b4 it was built... cost was over $6k and I never did finish it.
Another Inline six thred - chevy 250 Warrant Engine 7 10-18-2015 01:17 PM
250 inline six problems oldrat Engine 17 12-20-2008 07:15 PM
can i put an 250 inline carb on my1978 ford farmount kenarmy2001 Engine 4 07-19-2004 12:51 PM
putting an 250 carb on an 200 inline six kenarmy2001 General Rodding Tech 1 07-18-2004 12:32 PM
How to build a 250 inline 6? Cowboy_Germany Engine 2 07-10-2004 05:15 AM
