Inline 6 bellhousing for a T-5 - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
Old 01-03-2008, 11:58 AM
I'm building a 37 Gmc pick up I have a chevy 250ci inline 6 and a borg warner t5 out of a 95 chevy s10 what bell housing should i use. I have not done much with cars/trucks in almost 30 years (after raising 6 kids) so I'm a little slow with whats what anymore
Old 01-03-2008, 01:12 PM
The T5 transmissions that came behind the 2.2L engines introduced in '93 or '94 are a hybrid. The good news is that they're World Class. The bad news is that they use a Ford style mounting pattern and have a unique input shaft length. I have one also and have been investigating ways to put it behind an engine with the "traditional' pattern using an OEM bellhousing. The 5 speed Astrovan T5 used the Ford pattern, but I think it had the "standard"GM input shaft length. It's a problem I'm still researching, and right now it looks like it may take an aftermarket bellhousing. I did find that Bendtsen's Transmissions makes an adapter, but at $295, it's cheaper to by the earlier NWC S10 T5 and use a traditional Chevy Saginaw/Muncie/BW bellhousing.
Bob
Old 01-30-2013, 04:46 AM
Take a look at Hamilton Intakes | Unique blower and intake parts for your hot rod or kustom Also there is a really informative T-5 section in the "Tech Tips" on Inliners International devoted to all Inline powered vehicles I have 3 T-5's and all are different. Two 14 spline and one 26 spline with different input shafts and lengths. There are adapter kits made with the correct bolts also. I have all of mine coupled to Chevy sixes of varying engine sizes. I love all of them and they do take a beating too.
Normbc9
Old 01-30-2013, 05:05 AM
Crosley's Avatar
Wiki Edits: 1659
highball, thanks for the information. Read dates on threads as you search forums.
the original poster TheShoer on this thread has not logged in for 5 years. He may not see the message
The Following User Says Thank You to Crosley For This Useful Post:
Highball (01-31-2013)
Old 01-30-2013, 09:36 AM
S10xGN's Avatar
Gotta love a turbo!
I have an aluminum Jeep "Iron Duke" bellhousing which is identical to the Astro van bell. I bought it for an LS-1 project since they share the same bell pattern, but cannot use it because the bell only works with a 153t flywheel and the LS only came with the 168t flywheel. It does have the Ford Mustang T-5 pattern as Bob said, but those are all WC boxes and not the weaker non-WC. PM if interested...
Russ
Closed Thread
Bellhousing for BOPC to Ford T-85/overdrive Footstomper Transmission - Rearend 0 03-20-2007 11:44 AM
Chevy Bellhousing pattern Augusto Transmission - Rearend 6 05-12-2006 07:17 AM
which bellhousing nick62877 Transmission - Rearend 7 06-29-2005 07:02 PM
Lakewood bellhousing shagginwagonvic Engine 6 02-13-2005 04:51 PM
Bellhousing Question JamesRS Transmission - Rearend 7 11-15-2004 09:06 AM
