inline 6 gmc block casting location??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2011, 03:37 PM
GMC INLINERS
Where do I look on a 1952-54 inline 6 G.M.C. block for the casting numbers? I have this number by the distributor F12110BF ??????????? not listed on any info I have???? Help!!!
Old 09-11-2011, 12:16 PM
jalopy45's Avatar
Should ber a casting number on the right side near the distibutor along with a number cast in of your engine size (GMC only). Here are some more casting numbers that may help you. , http://clubs.hemmings.com/clubsites/...indercast.html ,
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
Old 09-11-2011, 01:32 PM
willowbilly3's Avatar
Last journal entry: Body mods
I have a 55 and the number is stamped showing that it's a 248. Maybe you have something like a service or replacement block. I think the 248 and 270 shared the same bore so a service block would likely not have been stamped.
Old 09-11-2011, 02:54 PM
Thanks.....for the help ....I have looked at all the supplied numbers for engines sizes....not seen anything like that stamped on the pad next to the distributor...I thought there might be a number cast on the block somewhere else>>>Thanks for your help G.T.
Old 09-11-2011, 04:27 PM
Gmc
What is the bore and stroke?
Ron
Old 09-11-2011, 06:39 PM
The engine is in a truck I am considering on buying so....I don't know bore or stroke???..nor does the owner. I need a 302 engine which has a 4inch bore x 4 inch stroke....that is why I am trying to locate block numbers to make sure it is a 302 before I buy it. Casting number 2193980 should be for a 302 for 1952-54. But I can't locate this number by distributor...I thought it might be somewhere else on block??? Most cubic inch numbers are located on pad by distributor.....this isn't the case on this motor.
Old 09-11-2011, 09:08 PM
Gmc
Measure from the pan rail to the deck. The 270 & 302 engines should measure 11 3/16" if I remember correctly. Smaller engines have a shorter deck height since they have a shorter stroke. By the way what kind of truck is this? Pickups didn't have 302's but not sure on the 270. I think the biggest engine in the later year PU's was the 228 cid.
I'll do some more looking to see what I can find.
Ron
Old 09-11-2011, 09:16 PM
GMC casting numbers
Can you pull the valve cover and get the casting number off the head? Then I can tell you what engine it is.
By the way I built a 321 cid Jimmy for a HAMB dragster and dynoed it at 347 HP @ 5600.
Ron
235 block number location wretched ratchet Engine 1 08-02-2011 11:28 PM
location of a 406 block?? Perfect Insanity Engine 11 02-12-2010 04:49 PM
Inline 6 casting numbers HELP SpeedCrazy Engine 11 05-27-2008 07:48 AM
small block location Prof. T. Soggmeyer Hotrodding Basics 3 08-20-2006 05:28 PM
SBF Casting Number Location Kenny13z3 Engine 1 09-10-2005 04:03 PM
