Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - inline fuel filters
Old 03-09-2009, 09:06 AM
freedom53's Avatar
freedom53 freedom53 is offline
Last journal entry: A Few Years Later...
Another take on the issue
I would think that the quality of the fuel filter element itself would be the crucial part of the equation. If you try to exceed the flow capacity of the element then any resistance(reduction in flow or pluggage) will suck/push the filter to failure. Perhaps a good ol' North American produced filter cartridge may be the solution- not some pos offshore crap??? How does the flow rating of the pump compare to the flow of the filter? Maybe the capacity isn't compatible?? Also the compatibility of the filter with the fuel used-maybe the moonshine/fuel additives are dissolving the filter
