inline pcv valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2010, 06:48 PM
streetrodderbn's Avatar
Certifiable Streetrodder
inline pcv valve
I'm running a 1965 365hp. aluminum intake manifold on a 1967 327. The filler tube is the stock 365 hp unit with a 3/8" barb and sealed cap. the road draft breather has the @1/2" right angle hose barb. I would like to run an inline pcv from the filler tube barb to the rear of the carb, and run the 1/2" tube from the road draft breather to the air cleaner base. any suggestions on the right pcv valve? what did the 65 365 hp vette use?
Old 06-13-2010, 12:52 PM
no suggestions?!!
Old 06-13-2010, 03:39 PM
You could just go to www.rockauto.com and look that application up for yourself...
Old 06-20-2010, 10:00 PM
I converted an old 283 from draft tube to PCV years ago. I used one that screwed into the base of the carb. Pipe thread on one end and hose nipple on the other. Spec was for a '65 Chevelle w/283-4V I believe.
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
cam question, any truth to this? 406 ss monte Engine 6 03-30-2008 11:28 AM
Crankcase breather or PCV Valve? Steves66 Engine 2 02-07-2006 10:53 AM
PCV valve info question... Juicer Engine 3 11-06-2003 02:54 PM
