inline6/v6 choices
I couldnt really find what i was lookin for in other posts so here it goes. I have a parts truck that i used to build my 69 gmc. I have enough to get it back on the road with what is left, except for the engine and trans. It is a 68 chevy stepside that i would like to use as a daily driver. Any suggestions on a motor /trans combo that would basically be a bolt in and get good gas milage. Thanks for ur input.
Neat project.If you can find a 4.3 V6 Vortech it is a good choice.I have built one that had 40k miles.I used a special 'Brock manifold,a normal electronic distributor,and had Crower regrind the camshaft to 270*.It gave us 300 HPs at 5500 rpm! Amazing.Stock pistons,compression,rods,valves etc.
Toss in a 4.2L I6 out of a Trailblazer
You could always find one of GMC's big V6's from the 60's - 305, 351, etc... - however, they weren't known for either power or mileage, and that probably would have been more appropriate in the GMC than in the Chevy, as they were GMC specific engines.
no I6. i would go small v8. make torque and have fun.before my buddy did his 289 mustang, he rebuilt the i 6 it came with. wasted a ton of money and wasnt fast.
i dont want to discourage you, but a american v8 is a reason to live. i would jump at the oppurtunity to use one. |
thanks for all of your input. I was looking at building a low budget 327 but i spent the money left over on my amc 390(amx). I thought a 6 might be a good combo with a 5 speed for a little inexpensive fun. A small 8 would be nice though. I will see what i can find at hershey this weekend or at the yard next week. Thanks again for all of your help.
Could u give me an example of your opinion of a conservative small block in this application. 305/327/350? backed by what trans?
Trailblazer 4.6
i would definatly not use the trailblazer's v6, it sucks a whole whole whole lot! i have a trailblazer and it won't even spin the tires and has horrable throttle response. it is stock though except for like a 1/2in. lift i did with parts i found around the shop but i don't think that has anything to do with performance. i would go with an ls1 my friend has one of those and gets 30mpg? with headers and a k&n filter and 3in exhaust. he can get a 12.86 1/4 mile with it ('02 camaro z28) i'm not sure on price but i'd immagine you could pull one out of a wrecked camaro from a junk yard for pretty cheap. have you ever been to Carlile (i think that's how U spell it) they have some pretty good swap meets up there (up for me i live in unionville/lancaster) you might be able to pick up a small block chevy there
I live outside of lancaster as well. There is only one problem with carlisle, it isnt until the fall i think. The ls1 is one option i was considering. Not the cheapest but an option. I was trying to stay away from a computer as well. Thanks for the input
Just had a twisted little thought...
Why not find yourself a 96-up 5.7 Vortec, and scrap the electronics. You can pick up a carb intake for about $100, new. Drop in an HEI, and slap the v-belt setup on the front. The only give away, that it isn't an old 283 would be the centerbolt valve covers, and no mechanical fuel pump. As a bonus, you'd have roller cam, and 64cc heads.
A properly built Q-Jet, and a set of 2 1/2" dump truck manifolds, should make it run very respectably. Not to mention acceptible mileage, if you keep your foot out of the big holes. |
). I stuck a summit cam in it, something like a 218/228 grind with about .450 lift on either side. It had headers and whatnot, decent HEI ignition. Clocked it at 22, COUNT THEM 22 MPG on the highway on its last trip back before I yanked it out. 2.73 gears and a TH350.The 388 (check my journal) gets... 12. K |
for me this is a no brainer inline 6 250 chevy with electronic ignition
up grade easy to work on strong motor my old 70 shortbed gets about 18 mpg up and down the hills of pa. and this baby seems to run forever if taken good care of !!!! |
| cam choices (.502 - .526) | corona jon | Engine | 0 | 05-16-2004 09:45 AM |
| Choices, Choices..... I need opinions | Centerline | Hotrodders' Lounge | 6 | 04-02-2004 10:16 AM |
| Outlaw 4 Cylinder Engine Choices | KSGerry | Engine | 13 | 06-14-2003 08:33 AM |
| Choices, Choices. What to do? | HemmiGremmie | Engine | 23 | 11-16-2002 10:31 PM |
| Hemi update and choices, choices! | HemmiGremmie | Hotrodders' Lounge | 3 | 09-07-2002 08:54 PM |
