Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - inner fenderwell or quarter first?
Old 07-23-2012, 03:38 PM
Mach1460's Avatar
Mach1460 Mach1460 is offline
Last journal entry: Project 92' Eddie
Im replacing both of these, since the inner braces the quarter panel im not sure if I should tack weld the outer patch in first then snugly fit the inner fenderwell up against the quarter then tack it in also then weld it all up? Seems to me that would be the best way.. ? any trick to doing this?
