-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   Inner liner at A-pillar Ford -34 fiberglass (http://www.hotrodders.com/forum/inner-liner-pillar-ford-34-fiberglass-232506.html)
scaryeyes 05-03-2013 06:09 PM
Hi
I would really like to see how you managed to cover the inside of the A-pillar of your fiberglass body. Some will be covered by the window frame, but how does it look arond the door opening? I have less than an inch gap between fiberglass , door to winshield.
Hope u know what I mean.
OneMoreTime 05-03-2013 10:01 PM
On the older cars the A pillar is painted body color which is what I would do with a narrow area like that..
Sam
bentwings 05-04-2013 12:52 PM
I made aluminum moldings, hammered on a leather bag with sand in it. I also used a shaped piece of wood clamped in a vise to finish hammering. Then I covered it with vinyl and used 2 oval head screws to attach each piece. I think they look like they belong there.
Plan on making each one twice.....the second one is always better.:spank:
You can easily anneal the aluminum sheet by blackening it lightly with raw acetylene then cook it off with a neutral flame. Be careful as the aluminum gives no warning before melting. Practice first.
DanTwoLakes 05-04-2013 07:16 PM
Or you could use PVC foamboard and spend a half hour making both pieces by heating the foamboard with an industrial heat gun.
302 Z28 05-04-2013 09:23 PM
Dan how bout some pics are even better a video. This has been a real pain area on my cars interior as I have several wires running up the "A' pillar. I have tried several methods but I am not satisfied with them.
Vince
scaryeyes 05-06-2013 11:11 PM
Yea! Like to see pics of both methods. Just to get an idea of how it could look like. The problem with internet pics, is that they almost never show that area. And the 34 fords glass cars are little rare here in sweden.
Im gonna put in pics how mine looks as soon as im home again.
/Magnus
itsjusti 05-07-2013 01:15 AM
I would glass it and make it a tunnel/hollow pillar. It will look good painted too and if you use a headliner it will give a nice corner for it to sit flush against. If you arent going to use a headliner take it all the way to roof to close it off.
DanTwoLakes 05-07-2013 07:42 AM
3 Attachment(s)
At the risk of over simplification, this is a piece of 3MM PVC foamboard. Literally, two minutes ago it was flat. You heat it until it gets soft and then bend it to whatever shape you want. To get a consistent curve, you should use a form of some kind, and use gloves. I did this with my bare hands. When it cools, it holds the shape you bend it in. If I re-heat it, I can flatten it back down, or make the curve even more pronounced. Now all you do is cut it, shape it, paint it, cover it with vinyl, whatever. It forms beautifully with normal woodworking tools.
