Inner Tie Rod Zerk Fitting Problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2011, 08:24 PM
I have a 66 Pontiac Lemans, anyone know where I can buy inner tie rods with the zerk fittings on the side? The ones I bought have the fittings coming out the back and they hit the frame. Or are they specified as something special. Thanks
Old 03-07-2011, 10:27 PM
SSedan64's Avatar
Some use a 90* Zerk & some have straight Zerk.
When I looked them up, one said 64-70 another said 66-70 I don't know if Power & Standard steering makes a difference or not.
You could always grease it then remove the Zerk & plug it with a set screw flush etc..
trans cooler fittings.. 3/8 hose fitting to a AN fitting? scapegoat Transmission - Rearend 6 04-14-2008 04:12 PM
rim fitting pcd HELP! 52prefect General Rodding Tech 5 02-06-2007 08:51 AM
Nova upper ball joint zerk fitting 68NovaSS Suspension - Brakes - Steering 2 07-18-2006 10:46 PM
i need AN fitting help Vortech 4.3 Engine 6 03-21-2006 07:21 AM
Rim fitting Mirror Image Suspension - Brakes - Steering 1 03-02-2003 12:28 PM
