Innovate Lm 2 question
I had to send my LM 2 back to Innovate because it started reading inconsistently[ channel 2 was all over, from 7 : 1 to 64 : 1 AFR] It started that after I updated the firmware.
Anyway, I got it back, it calibrates fine [20.9 both channels].
My problem/question:
At idle it's reading 16:1, same at light throttle cruise.
When I tried to richen the idle screws, the engine started running worse and the exhaust started to burn my eyes.
Has anyone seen an LM 2 read incorrectly or should I look at the ignition?
it idles at 800, plugs are a little gray, but not terminal. I'm not driving it except around the block until I get the basic tune straight
It is very frustrating when you can't trust your equipment.
351C Ford 10:1
Solid flat tappet, 236@.050
Edelbrock air gap, holley 3310-1
14* initial
Thanks
Reason: add info
