Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - INPUT I NEED INPUT PLEASE
Old 06-28-2002, 07:34 PM
Tom Tom is offline
When you take out the cam, if you are not replacing the cam berings be careful of them. What I do is get 3 long 1/4-20 bolts (like the long q-jet bolts)screw them int the cam and use them like a handle,go slow,out and in,use a good cam lube. soak the new lifters overnight in oil so they are filled when you put them in,arrange them in a can so they are upright then pour the oil over them. get a thrust bering,keeps the cam from walking back and forth.they also make a bolt lock for the cam bolts.use new time set, I like cloyes, the 20 dollar set is good...good luck
