Input on my 383 setup - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-27-2012, 09:19 AM
my87Z's Avatar
Veteran/Firefighter-Paramedic
first question I have to ask is whether you are using an LT1 block or not? I ask because I see that you are trying to use a LT1 "hot cam". I've personally never messed with an LT1 before but if I'm not mistaken I believe the cam between an LT1 and a Gen I small block are not interchangeable. I could be wrong but I'm almost certain.
The shortblock with the -4cc flat tops along with a 72cc head will put you at 10.2:1 so that is right about where you want to be, I didn't look at the specs on the cam you chose but I would assume that you would want to with around a 230°ish @ .050 cam with around .525-.550" lift.
Everything else sounds pretty good, although I've never fooled with an FI set up either, I like good ole' simple carbs.
  #17 (permalink)
Old 12-28-2012, 07:43 AM
suspect's Avatar
Smoke Signals
I've wondered this same thing. I found out it's a '96 block (1024388C). I think it's from GM's crate motor line. I believe it's Gen 1 though, but when I search for parts like on summit racing and I put in '96, only LT stuff comes up. So I leave the '96 out and put in Gen 1.
When I requested a cam from Lunati, I said a '96 block and the LT cam is what they came up with. Once I actually order, I would call them up and discuss what I have.
Thanks for pointing that out though. I would like to hear more on what everyone else thinks about this Gen 1 & LT stuff.
  #18 (permalink)
Old 12-28-2012, 08:50 AM
my87Z's Avatar
The 96' block could be an LT block because it wasn't until around 97-98 that they started using the LS blocks regularly. But more than likely its a 96' gen I block with a OEM roller cam. You need a OEM style roller cam, not a retro fit style roller cam. Also you will need OEM style roller lifters and not retro fit roller lifters. Typically the OEM style is slightly cheaper.
383 stroker setup killab1989 Engine 22 06-07-2012 09:51 AM
383 Stroker Build - Just looking for input ziatzev Engine 7 09-17-2009 08:00 PM
Input for Chev 383 small block build Calais Engine 64 01-12-2009 12:12 PM
383 SBC, need input for performance issues roxanne68 Engine 24 08-08-2007 11:06 PM
383 setup bobo_r2 Engine 0 08-27-2002 02:58 PM
