input needed on 4l80 builder for high hp application - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2012, 01:53 PM
psbaker75's Avatar
Hi folks, so I'm in the design and planning stages for my build. Basically, I'm looking at a ls 408 twin turbo build that should net about 800 rwhp on pump gas, upwards of 1000+ on race gas, and I'm looking for input on my trans choices. I'm heavily leaning towards a 4l80 with paddle shift. It will primarily see street duty with maybe 4-8 track trips a year. I've been looking at phoenix, mad dog, jakes, and bowtie overdrives, but I wanted to see if anyone had any real world experience with these builders or any other shops you would recommend. This will be a weekend warrior, not a daily driver, but I still want something as reliable as possible. Any input is appreciated. Thanks
Old 04-04-2012, 07:29 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
This is like my dream build! Best of luck good choice on motor and trans!
Old 04-05-2012, 06:28 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
I am using a 4L80E in my build also, and I think you are choosing the best automatic, high horsepower transmission there is for performance and mileage in a Chevy.
Are you going to build it yourself, or buy it from a Builder? What is the rest of the build? Rear Axle? Suspension?
Old 04-05-2012, 01:02 PM
psbaker75's Avatar
I'm leaning toward a strange s60 rear with 411 gears, ride tech tubular control arms with adjustable coil overs
Old 04-05-2012, 07:18 PM
4l80 trans
Second that choice , what about gearstar transmission! they build for high performance , in the range you are talking about
Old 04-06-2012, 01:34 AM
SSedan64's Avatar
GearStar is a little too draining on the Wallet.
I'd go with:
Jake >> http://www.jakesperformance.com/4L80E.html
Lonnie >> http://www.extremeautomatics.com/tra...ons/4l80e.html
Chris >> http://www.ckperformance.com/resourc...0ECATALOG.html
Old 04-06-2012, 07:04 AM
35WINDOW's Avatar
Originally Posted by SSedan64
I second this, as I am using a Jake's 4L80E (Stage 3)they know their stuff-
Old 04-06-2012, 08:28 AM
Jake Lonnie and Chris are top notch guys;
Id also throw 2 more names in the mix:
RPM Transmissions in Indiana (http://www.rpmtransmissions.com/projects.html ), they're doing some killer transmissions these days and getting a lot of magazine pub. I believe they still have the fastest 4L60e around.
Id also mention Chuck at FinishLine Trans in Illinois (http://www.finishlinetrans.com/ ).
You wont go wrong with any of these guys, I think it really depends on how long you want to wait to get a unit, and how much money you want to give to the UPS man
Old 04-06-2012, 10:05 AM
psbaker75's Avatar
Great input guys, thanks. I'm going to have to check some of these out. I looked at the gearstar unit and it looks top notch for sure, but 8600 is a serious dent in the wallet. I'm trying to educate myself as I go, so that when I'm ready to pull the trigger I'm confident I'm making the right choice. I foresee a lot of conversations with vendors in the near future.
4L80-E slips in R. high line pressures mastermechanic99 Transmission - Rearend 1 02-27-2012 07:25 PM
Aluminum Wheel Painting / Aluma Prep Application Help Needed jmacs53Willys Body - Exterior 6 04-07-2009 03:58 AM
Help needed for trailing arm application renfroe453 Suspension - Brakes - Steering 2 03-15-2009 01:48 PM
ebay input needed phatwagon Engine 5 05-18-2004 10:26 AM
Builder Needed danker Hotrodders' Lounge 16 02-25-2002 06:39 PM
