Input shaft conversion for C4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2003, 12:11 PM
k2mooch's Avatar
I read a few articles in the KB and tech and have a few questions about the 24 tooth to 26 tooth input shaft upgrade for a C4. I have a '69 case fill with a 6 cyl bellhousing with a 24 tooth input shaft. The other transmission I have is an '83 C5 with a 26 tooth and components. Will these interchange, or do I need another C4 with a 26 tooth input shaft?
I was under the impression that the C5 is like a modified C4 and some parts would interchange, just wanted to be sure before I went ahead.
Also, is there any way of knowing if my '83 351W truck motor has a 157 or 164 tooth flexplate? I need to be sure of what bellhousing to get for my case fill C4 to bolt it up using the 26 tooth input shaft and c5 torque converter. Thanks in advance.
MoocH
Old 12-09-2003, 07:10 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Re: Input shaft conversion for C4
the parts will interchange, but........
Watch for the early case needing an O-ring seal on the pump. I cannot remember what year Ford changed the front area of the case to where an O-ring is NOT used.
There is a little hole in the case at the pump gasket area that must be pluggged off if a NON O-ring pump is used. The hole is at the pan rail level and it connects to the pan area. No O-ring and the oil will seep by and leak.
Your truck should have the large flywheel
MoocH
Old 12-09-2003, 07:31 PM
airworld2's Avatar
c4
why would you want to change input shaft?are your parts bad and you need replacement parts? I know some people that restore old mustangs that wouldn't change the parts with me its what ever parts I need at the time that get changed.as far as concerning the hard parts on a rebuild
airworld2
Old 12-15-2003, 07:34 AM
k2mooch's Avatar
I want to change out the 24 tooth spline just because I'd rather have something stronger in there. If I'm not mistaken, they rarely used a 24 tooth on the V8's. If I have something bigger and stronger to change it out with (26), why shouldn't I? If I can find a torque converter to fit a 24 tooth spline and durable enough to not break my input shaft (or the components inside that it's connected to) then tell me it's safe and I'll go shopping tomorrow and save myself the hassle
I'd rather just do this and not tamper with the C4, but I'm just worried that the 351 will put too much stress on the front parts. Any suggestions? Thanks fellas.
MoocH
Old 12-15-2003, 08:28 PM
airworld2's Avatar
c4
never seen that shaft brake in all my years rebuilding. yes they did you the small shafts behind small v-8's till 1970
airworld2
Old 12-16-2003, 08:44 AM
k2mooch's Avatar
Sounds good to me. I was just under the impression that the 24 was meant for 6 cyl's and low-power smallblocks like the 260/289/maybe 302. I didn't want to put any extra strain on it from a 351.
If Ford used the 24's before and had little problems, I'm cool. I probably won't dog it bad enough to break anything. Just looking for durability. Thanks for the help guys. I ordered my new lockup converter yesterday and hope to have it all together by christmas.
MoocH
Old 12-16-2003, 06:23 PM
adtkart@aol.com
I also have never seen one of those shafts break. If you break it, you are going to be breaking other things too. It;s been a while, but I thought the only difference, was the number of splines on the shafts.
Old 12-17-2003, 06:40 AM
airworld2's Avatar
c4
most converter re builders have omitted or deleted lock up components on c5 (80's type) converters for years never held up was as my understanding a horse shoe lock up like go cart clutch.
airworld2
Old 12-29-2003, 10:36 AM
k2mooch's Avatar
www.accuratetrans.com
These guys will custom-build any converter to specs you provide and ship to Auto-Zone for purchase. Mine is a ford lockup with an 11.5 bolt pattern to fit a 164 tooth large flexplate that mates to a '69 C4 with a 24 spline input shaft. It's almost impossible to find one that large with a 24 spline since late-model C4's, C5's and C6's all used a 26 spline.
I highly recommend Accurate Transmissions to anyone trying to mix and match anything. They are extremely helpful. Thanks guys for all your help. I'm on my way now.
MoocH
