input on tuning turbo sbc. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2011, 04:04 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Ok everyone. I am putting together a sbc 355 with a single T-70 turbo. Its going in an S10 and is strictly a drag vehicle. I have a holley 650dp that i will convert to blow through. I planned on locking the mechanical advance out of the dist and just running around 20* of timing. I will have a wideband O2 gauge on it for sure to keep a close eye on the afr.
I plan on getting it running NA at first and after i get everything settled with the motor then hookup the turbo. I will then set the carb on the rich side run just a couple psi do an 1/8 mile pass and keep an eye on the afr. as it starts leaning out. I will richen it back up and then do another 1/8mi pass with some more boost and just keep going back and forth until everything is all set. Then when i am happy with the afr and plugs i will do a full 1/4mi pass and hope everything works out good. Does this seem like a good way to do the tune?
Thanks!
Old 01-13-2011, 05:40 PM
carnahan's Avatar
you should probably put this ? in the engine section
Old 01-13-2011, 06:14 PM
Listen and Learn
Wiki Edits: 7
can a moderator move it please? thanks
Old 01-13-2011, 08:36 PM
Listen and Learn
Wiki Edits: 7
alright nvm ill just move it over to the engine forum.
Carb Tuning Input/Thoughts (blower) camaroman7d Engine 20 12-16-2008 02:22 PM
Need some input on Turbo 400 dave454bb Transmission - Rearend 3 12-20-2006 07:53 AM
Thrush Turbo or Dynomax Super Turbo? henkelphoto Engine 3 08-24-2006 11:46 PM
turbo 350 tuning problems RODSBYT Transmission - Rearend 1 11-03-2003 09:06 PM
Turbo 350,Turbo 400,700R4,Or Muncie 4 Speed nightrain_rod Transmission - Rearend 2 04-18-2003 12:35 PM
