Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Inquiring about 700r4 tv cable
Old 02-18-2013, 01:34 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
Starting to sound like trash or wear causing binding, TV valve/sleeve maybe.
If it does it again, disconnect the TV cable, engine running, E-brake on, snatch cable a dozen or so times & reconnect.
There's also a Governor screen under the Valvebody at rear that can cause problems if restricted.
The Following User Says Thank You to SSedan64 For This Useful Post:
Slammedsi (02-18-2013)
