Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Inquiring about 700r4 tv cable
Old 02-18-2013, 04:03 PM
Slammedsi's Avatar
Slammedsi Slammedsi is offline
Originally Posted by SSedan64 View Post
Starting to sound like trash or wear causing binding, TV valve/sleeve maybe.
If it does it again, disconnect the TV cable, engine running, E-brake on, snatch cable a dozen or so times & reconnect.
There's also a Governor screen under the Valvebody at rear that can cause problems if restricted.
Thanks SS, I think at this point there is not point in not changing it out. The other 700R4 I have is already set up to support 500whp and has a shift kit and other goodies.
Might as well get it over with...
