ok you guys ready for this? hope you can keep up don't let me loose you here
alright i was getting ready to rebuild my 383 stroker and i already have my new pistons, there for a 5.7" rod. Then i had a change of mind and was going to return them for a 6.00" rod, but then i had this monstrosity of an idea
what if i kept my pistons that i have now (for a 5.7" rod) put them on a 6" rod & a 302 crankshaft w/a 3.00 stroke then wrapped it all together inside of a 350 block?
ok i know somebody out there will say it won't work just because these parts werent' originally ment to be together, but i don't believe thats true (obviously). Heres what i came to conclude thus far:
I take the stroke of my crank & divide it in half which will give me 1.5", than i add the 6" rodd in there,& last but not least i throw in the distance from the wrist pin to the piston head which is 1.56"
ok you still w/me? this is what i got so far:
1.5" + 6" + 1.56" =9.06"
alright everyone knows that the deck height is 9.025 (unless it's modified, or a custom block, or something) so if you take the deck height 9.025" - 9.06" stroke = -0.035"
do you fellas think i could take the crank to the machine shop and have them grind & index it to decrease the stroke a little bit so my pistons would be just inside the deck height? I think it might be possible, but every motorhead is like a doctor it's nice to have a 2nd oponion, or a 3rd, or a 4th,etc......
thanx all
Jesse
