-   -   Inset Bleeder Screw (http://www.hotrodders.com/forum/inset-bleeder-screw-232548.html)
27Tall T 05-04-2013 10:03 PM
Inset Bleeder Screw
:confused:I wish to bleed my brakes and find that the rear axle has the bleeders inset into the brake cylinder. How does one turn the bleeder screw if a hose is attached to it (using a vacuum Bleeder)? There is no room for a wrench, only a socket, let alone enough room for the hose. I have never seen a set up done this way by an OEM. I believe that the rear axle is GM. I could do it the old fashion way and open the bleeder with a socket and have it leak done my arm and on to the floor, but that's messy. Any further thoughts?
poncho62 05-05-2013 05:06 AM
Pull the hose off and tighten while holding the brake pedal down.
2old2fast 05-05-2013 07:10 AM
Take 1 of the bleeder screws out & see if you can match up a longer version [I'd try napa] Same thread & taper w/ a longer body...
dave
302 Z28 05-05-2013 08:26 AM
Replace the OEM bleeders with "speed bleeders" makes the task of bleeding brakes much easier. Be thankfull you can get the OEM bleeders out. When I was building my 34 one of the Willwood polished billet calipers had a bleeder that was stuck. Despite all my effort to free it it finally snapped off. A new caliper cost me some $$ and I still have that caliper with the broken bleeder screw.
http://www.hotrodders.com/gallery/da...m/DSC_0043.JPG
Vince
boothboy 05-05-2013 09:01 AM
Vince
Never saw them before , slick idea!
BB :thumbup::thumbup:
st3gamefarm 05-05-2013 09:51 AM
Vince
Will a lefthand drill bit be of any help with the broken bleeder screw?
302 Z28 05-05-2013 12:10 PM
Tried that and several other suggestions the bits just walk off the harder material and gouge the surrounding aluminum.
Vince
