Inset Bleeder Screw - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2013, 10:03 PM
Inset Bleeder Screw
I wish to bleed my brakes and find that the rear axle has the bleeders inset into the brake cylinder. How does one turn the bleeder screw if a hose is attached to it (using a vacuum Bleeder)? There is no room for a wrench, only a socket, let alone enough room for the hose. I have never seen a set up done this way by an OEM. I believe that the rear axle is GM. I could do it the old fashion way and open the bleeder with a socket and have it leak done my arm and on to the floor, but that's messy. Any further thoughts?
Old 05-05-2013, 05:06 AM
poncho62's Avatar
Wiki Edits: 5
Pull the hose off and tighten while holding the brake pedal down.
The Following User Says Thank You to poncho62 For This Useful Post:
27Tall T (05-05-2013)
Old 05-05-2013, 07:10 AM
Take 1 of the bleeder screws out & see if you can match up a longer version [I'd try napa] Same thread & taper w/ a longer body...
dave
The Following User Says Thank You to 2old2fast For This Useful Post:
Old 05-05-2013, 08:26 AM
302 Z28's Avatar
Replace the OEM bleeders with "speed bleeders" makes the task of bleeding brakes much easier. Be thankfull you can get the OEM bleeders out. When I was building my 34 one of the Willwood polished billet calipers had a bleeder that was stuck. Despite all my effort to free it it finally snapped off. A new caliper cost me some $$ and I still have that caliper with the broken bleeder screw.
Vince
The Following 2 Users Say Thank You to 302 Z28 For This Useful Post:
27Tall T (05-05-2013), boothboy (05-05-2013)
Old 05-05-2013, 09:01 AM
Vince
Never saw them before , slick idea!
BB
Old 05-05-2013, 09:51 AM
Vince
Will a lefthand drill bit be of any help with the broken bleeder screw?
Old 05-05-2013, 12:10 PM
302 Z28's Avatar
Tried that and several other suggestions the bits just walk off the harder material and gouge the surrounding aluminum.
Vince
Bleeder screw size and ... Babyburr Suspension - Brakes - Steering 2 01-08-2011 07:29 PM
Bleeder screw locked tight truckboy61 Suspension - Brakes - Steering 8 06-18-2010 06:42 PM
Hydraulic clutch bleeder screw henny496 Suspension - Brakes - Steering 13 06-30-2009 12:05 PM
Fluid seeping out of bleeder screw. SuperSport Suspension - Brakes - Steering 13 12-02-2006 09:38 AM
stripped bleeder screw APACHEMAN Suspension - Brakes - Steering 3 08-26-2003 10:35 AM
