inside info - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2007, 10:02 AM
inside info
Hi All,
I want my '89 Iroc to end up with a 6 point cage that's finished and probably at least partly wrapped with foam or whatever, aftermarket seats (Arizens look like good value for the $$), no rear seat and new carpeting. I'm going for a more or less luxo road racing look.
My question is: What do I do first after I've removed the seats and the old carpet?
I want a welded cage so my first thought is to do that with the interior out of the car so the welding can be done with no worries about damaging the new carpet. On the other hand, I read recently that installing carpet with a cage in place is difficult because access is limited by the tubes and it all has to be installed around the tube attachment points.
I'm also not clear on how to make sure an after market seat is going to work with the cage.
Any comments or advice is appreciated.
What's a Mutha to do? :-)
Chuck
Old 07-06-2007, 10:13 AM
Hi all,
I want the interior of my '89 IROC to end up with a six point, crackle finish, at least partially foam wrapped, welded cage, aftermarket seats (Arizens look like good value for the $$), no rear seat and new carpeting. I'm going for a luxo road racing look.
My question is this: What do I do first after the old seats and carpet are removed?
My first thought would be to do the cage so that welding, etc. can be done with no worries about damaging the new carpet. On the other hand, I recently read that carpet is very difficult to install with a cage in place due to restricted access to the interior, especially in the back seat area.
I'm also not clear on how to manage fitting aftermarket seats with a cage in place.
Any advice or comments are appreciated.
Thanks in advance,
Chuck
Old 07-06-2007, 10:42 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
H'mm double posts..well get the seats that you want and a cage kit if you have not done this before..set the seats into place so you know where they need to be and then layout and install the cage..get the cage welded and painted and then proceed with whatever you plan on the rest of the interior..
I would need to have you in the shop so I can get the seat fitted properly..once that is done then the cage can be installed..
Sam
Old 07-06-2007, 11:31 AM
Sam,
It looks like I'm going to need the help of professionals like yourself. I'm far enough away from you that I probably need to find someone in my area. Any tips on how to find a good shop to work with? I'm between San Francisco and Sacramento.
Chuck
Sorry about that double post...
Old 07-06-2007, 06:41 PM
creativeinteriors's Avatar
Stitching or grease I love it
Last journal entry: Wings and Wheels fly in
Make sure you know what you want for an interior before you install a roll bar
Here are my thought from hard learned experiences that I have from roll bar cars.
1st decide on why you want the bar. There are several different ways to fab the bars and what the ultimate strength wanted will have a great deal of impact on the bars overall construction and dimensions to you as the occupant.
2nd decide on what the other interiors pieces will be. Do you want a stock dash, door panels and or interiors quarters. This has alot to do to what the routing to the floor and location are going to be. I have seen bars that prevent access to anything and heaven help you if you need to get a dash out after the fact or inside the cowls covers.
3rd decide on what kind of padding do you want. In many places (with exception of door openings) bar padding is more of a creature comfort than anything 1/2 high density should cover most apps. If the bar is low enough to hit your head on it without a helmet than you should consider again how the bars built because with a helmet you probably cant sit comfortably in the car.
Door bar padding if needed for impacts can be covered with roll bar foam covers that are about 3 inches in diameter but are biased so that the pad is about 1 1/2 inches to the occupant and 1/2 to the door.
4th and finally is the seat because the bar to any inner structure like a console or a tunnel
In the end a interior person should be consulted on the interior panel impacts before the bar is installed so he or she may have a chance to guide you and the fabricator of the bar on the clearances if access is needed.
hope this helps a little Good luck
Old 07-06-2007, 07:45 PM
454 Rattler's Avatar
NEVER SATISFIED !!
You might want to check with your insurance company. Some of them won't insure a car with a bar. Also check their rules on wheel tubs. Shop around !!
Good Luck,
454 RATTLER
Custom intake tube info (Cavalier, but good info for all) TheVis Engine 11 02-09-2007 05:44 AM
Displaced Arizona rodder signing in, project pics inside!! TheVis Introduce Yourself 3 01-21-2007 05:15 PM
who wants to build their own Mustang II front suspension? measurements inside !!! lowROLLERchevy Suspension - Brakes - Steering 1 09-07-2006 09:33 PM
Need info about the th350 transmission joe350s10 Transmission - Rearend 1 07-01-2006 10:44 PM
windsor info Blag Engine 1 04-24-2003 09:08 PM
