inspect and clean hyd. roller lifter - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2013, 12:24 AM
tapkoote's Avatar
Last journal entry: like a little kid
An old thread from2004 tells how to break them down.
The pics are gone, can't find much on the inner web.
Put one in a vice and some pressure, it didn't appear to want to move. Just how stiff are these springs any way?
This is a scrap yard motor so who knows how long it sat.
Soaking them in stinky stuff right now.
Would a little heat help?
thanks Pat
Old 09-30-2013, 12:42 AM
vinniekq2's Avatar
get more lifters if they are GM roller block lifters
Old 09-30-2013, 05:07 AM
jokerZ71's Avatar
Wrench Turner
You can get a set of the Delphi OEM roller lifters from Skip White Performance for $98.Best deal I've found so far on GM rollers.
Old 09-30-2013, 07:41 AM
Last journal entry: Still running strong
I took some apart, they were roller lifters from a Chevy 2.8 L. Take out the retainer an the cup, then I used a short Chevy head bolt an wrapped electrical tape around the threaded end. I wrapped it 3 or 4 times then took some off for a better fit. Then I put the taped end into the lifter an pushed that in by using my big bench vice. I pressed the bolt into the lifter untill it was getting tight. Old oil will come out of the hole on the side. Then I took it out of the vice an started to pull the bolt out with my fingers an the tape sort of acts like a cork an you can pull out the piston from inside of the lifter. You want a real tight fit with the electrical tape but not so tight that the tape is pushed off the bolt when compressing it. That old oil inside the lifter acts like a seal, I tried soaking them also didn't work. Some O-rings on the threads of the bolt might work as well. Theirs a small spring, ball bearing an a small round disc with a hole in it. I wouldn't use air on the hole on the side of the lifter cause those small parts are going to fly. More than half of them I had to use needle nose pliers to pull out the piston.
Old 09-30-2013, 08:37 AM
Banned
what kind of fubar'd lifters are you working with? Pull the retaining clip and they come apart pretty easily. If they don't get another set, they're all over the junkyards. With thousands of them to choose from why pick the ones that are likely the most worn?
Old 09-30-2013, 10:15 AM
tapkoote's Avatar
Ford 302
Should have stated SBF 302, thanks for the help.
Hyd roller vs Hyd flat tappet for sbc SJSS Engine 6 12-23-2011 12:02 PM
roller lifter vs hyd flat tappet 001mustang Engine 20 01-30-2011 07:58 PM
Hyd. Roller Lifter Check.....Check greenmoonshine Engine 11 07-22-2009 01:25 PM
how to inspect roller lifters and oil pump? slate84 Engine 4 03-11-2009 09:59 PM
plz help,,,1988 vette 350 hyd roller motor can i convert it to hyd non-roller?? tiresmoke55 Engine 20 05-24-2006 02:51 AM
