Inspecting a big block chevy with a video stik - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2009, 07:09 PM
Hey thanks in advance to anyone who answers. What can one learn about the condition of an engine when using one of those hand held video stiks? I guess more specifically, what should I be looking for when looking in the spark plug holes with a 36" fiber optic video camera, in a 454 bbc 0.030 over with, supposedly, 120 passes (1/8 mile) since rebuild? Also, is there any other part of the engine I could or should use the video stik to inspect? I am considering buying this engine, just want to know as much as I can before I put it in my camaro!
Thank You Much
Name:	73 Camaro Driver Side.jpg
Old 10-16-2009, 07:49 PM
BOBCRMAN@aol.com's Avatar
I have used a Snap On stick on these. Check for carbon pattern on tops of pistons and the valve faces. Check for any marks on cylinder walls. Walls should be uniformly shiny with NO black streaks or scratches.
Difficult to inspect lower end thru drain plug. Main caps and oil pump get in the way. Oil gets on lens. Check rods for dark coloration. Heat marks
Old 10-16-2009, 08:00 PM
Thank you for the input. You say carbon pattern, like if there is an abnormal, off center, or darker than the others dark pattern on the piston top or valve face?
Thank You Again
Old 10-16-2009, 08:54 PM
The center of piston top will show grey carbon, diminishing outward to the edge. Patterns should be the same cyl to cyl. The intake valve will have light deposits on face. Exhaust will light brown-grey and even across face. Chambers should show even color except on quench area.(flat part) This should have very little color.
Old 10-16-2009, 09:00 PM
Thank you very much for the help.
Big Block vs Small Block Chevy bigjoedo Engine 82 05-03-2010 03:36 PM
Big block water pump on small block! TVR383 Engine 14 04-15-2008 07:43 AM
Big Block Chevy ... How much does a block weigh Rob Keller Hotrodders' Lounge 5 03-24-2008 06:10 PM
Big Block Chevy Pushrod length Choctaw Bob Engine 13 04-16-2006 11:54 AM
Swapping to big block chevy low77ride Engine 5 09-15-2004 09:30 PM
