Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Inspection of Edelbrock Performe RPM heads
Old 01-19-2013, 02:10 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
You can check and measure the side to side valve deflection in the guide, by hand. The magnetic base will not stick to the cylinder head. You can visually inspect the valve job and wet/leak test it easily enough.
