Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Inspection of Edelbrock Performe RPM heads
Old 01-21-2013, 10:12 AM
prostcelica prostcelica is offline
Thnks for the info Jim. When lapping the valves what is the best way to "spin" the valve?? Ivess the little tool that suctioin to the valve and you spin it in your hand. I've also see this done with a drill. Aslo because the heads have been in service, when I remove the valves is it neccasery to pyt the valves back into the same chmaber they came out of??
