install break pedal to fire wall on 1951 chevy deluxe - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2013, 02:09 PM
need help : i have a 1951 chevy fleetline deluxe. i removed the pedals from the floor and i have replaced the gas pedal, but i need to hang the break pedal and mount it to the firewall. please help ! thank you,rmrm
Old 01-26-2013, 07:31 PM
tnovot's Avatar
And your queston is? Are you trying to use the original pedals on the FW? Do you have something else ready to use and need to know how to mount it? Are you looking for an aftermarket pedal assembly? Do you want to know what used/junkyard pedal will fit?
You would receive helpful advice if you supply details and info to us so we can understand what you are asking.
Terry
Old 01-26-2013, 09:01 PM
Wiki Edits: 27
hanging pedals
In the late 50's the hanging pedal of choice were Fords , mid 50's, The reinforcing ribs on your firewall might cause interference, Today most builders want the firewall clean, minimal stuff visible. Things to look at , space available and the angle of the master cylinder, size of a power booster, outlet ports on M cyl. Bracing needed to keep firewall from flexing . pedal to floor clearance. pedal support to steering column and dash.On the last one we did, we added a 1/4 in thick back up plate about 6 X 16 inches to the firewall to minimize flexing. .
how to install a v6 into a 1951 chevy deluxe phillip tidwell Engine 1 02-04-2012 10:12 PM
1951 chevy deluxe 4door chop swain66 Body - Exterior 1 06-10-2010 08:04 AM
1951 chevrolet Styleline Deluxe ClassicDee Introduce Yourself 1 05-08-2009 05:42 AM
1951 chevy styleline deluxe booster OC51CHEVY Suspension - Brakes - Steering 3 02-17-2009 10:40 AM
'66 Chevy C-10 Fire wall dar130 Interior 2 01-21-2009 06:15 PM
