install camaro rear - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2012, 02:43 PM
install camaro rear
is possible to install camero rear in a 1955 pickup, if so any instructions.
Old 11-06-2012, 02:57 PM
302 Z28's Avatar
What year Camaro?
Vince
Old 11-06-2012, 02:59 PM
big gear head's Avatar
High Performance Rear Ends
Yes, you can install a Camaro (no E in Camaro) rear end in a '55 truck. If I remember correctly they are the same width, as long as you are talking about a first gen Camaro. These are 60 inches wide. The second gen Camaro rear end is 61 inches wide and the third gen Camaro rear end is not even worth talking about. All you have to do is cut off the Camaro leaf spring perches and weld on narrower spring perches for the truck springs. You must get the angle right so that you don't run into problems with your pinion angle.
Old 11-06-2012, 06:48 PM
ogre's Avatar
the 'Duracell Project'
what year camaro and what version of 55 chevy truck?
regardless of what big gear head says...
i have a 3rd gen 86 trans am rear end under my 58
on stock 58 springs, using the 86 sway bar and the 86 torque arm
it's the right width, the right 3.27 ratio and has held up to my 350hp sbc for 3 years
Old 11-06-2012, 07:40 PM
Ogre, you have the Borg Warner 9 bolt, not the weaker 7.5 10 bolt that is much more comon in the 3rd gen Camaro. The BW rear end is quite a bit stronger.
1989 Camaro with a 1969 camaro rear will it look good??? Opinions!! nealey101585 Hotrodders' Lounge 63 06-23-2012 03:03 AM
Camaro clip install woes 80ta General Rodding Tech 8 01-14-2011 10:02 AM
Camaro clip install Rodder41 Suspension - Brakes - Steering 15 03-28-2007 07:27 AM
Install 502 into 67 camaro camaro502 Introduce Yourself 5 09-18-2006 04:17 PM
34 pontiac 81 camaro subframe install ? mobythevan Suspension - Brakes - Steering 7 05-19-2005 12:17 PM
