install Harmonic balance '66 model 327 SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2010, 10:20 PM
Could someone advise me on re-installing the harmonic balance on a '66 model 327. The crank hole is NOT tapped as it only has the tapered bore in the end of the shaft. Obviously this eliminates a balance install tool that would thread and pull the last bit. Is it safe to "hammer' it on. It sure seems to be awfully tight already and it seems to have about 3/4" to 1" left to go on. I've read both opinions about hammering including using a block of wood and the sort. It does concern me about whacking on the crank alot, but i'm out of ideas. Thanks so much.
Old 07-28-2010, 10:35 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You should remove the damper and heat it using boiling water. I've heard of guys also using ice on the crank snout, and also hitting it w/a CO2 fire extinguisher to shrink it down.
Hustle the damper out to the crank, get the keyway aligned w/the key (both of which you've already deburred) and using a thick piece of wood, like a short piece of small diameter fence post, end-on- wail the damper on w/a BFH. Do Not hit the outer edge of the damper- just the center of the hub.
If the engine is in the car, it helps if you have someone under the car that can lever the crank frontwards after every hammer blow. This lessens any impact that the thrust bearing will see. If the engine is on a stand, simply lever the crank forward after each blow. You gotta move fast, though. And you'd like to have a smear of silicone or "Right Stuff" inside the damper ID to stop any seepage of oil past the press fit.
sbc identification numbers ? 68 Chevy C-10 Engine 23 01-19-2010 12:02 PM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 10:12 PM
327 SBC identification numbers ? 1 Day Engine 2 07-11-2004 07:29 AM
'28 Model A rearend and 283 install GeneS Interior 5 12-21-2003 08:29 PM
Spun #8 on '66 model 327 C20 T56SS Engine 1 09-19-2002 04:57 PM
