Install harmonic balancer. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2010, 01:00 PM
bigdog7373's Avatar
Of course it's fast
Alright, I'm in the process of building a chevy 350 and I just pulled the harmonic balancer off so i could get at the cam. The problem is that the are no threads in the end of the crank to get the balancer back on... How can i get it back on without drilling and tapping a hole in the crank?
Old 05-31-2010, 01:21 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I had a '68 327 that had no threaded hole in the crank, either. I ended up using a short piece of 4x4 lumber and a BFH. The oil pan was off and the engine on a stand, so after each hit, I would move the crank back forward, away from the thrust bearing making contact w/the crank's thrust surface. This prevented the bearing from being damaged.
If I'd have had the time and inclination, I would have drilled and tapped the crank for a crank bolt. If you drill and tap for a crank bolt, get the hole straight to the crank centerline.
Old 06-03-2010, 09:09 PM
Be sure you only pound on the hub, and not the outer ring of the damper. .
Old 06-03-2010, 09:36 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
See "Installing the damper" here....
http://static.summitracing.com/globa...sum-163289.pdf
Old 06-04-2010, 12:16 AM
327NUT's Avatar
A trick I learned long ago on the non-tapped crank hubs was to put the harmonic damper in the oven @ 200 for 20 minutes. Place some ice cubes in a sandwich bag and lay them over the crank hub prior to the "baking" of the damper. Quickly wipe any moisture off the hub and slip on the damper which is still a press on fit, just doesn't need so many hvy blows with the infamous BFH. You can use the same procedure with a threaded snout, pulls on a lot easier.
Harmonic balancer ring 180 deg. off? 9K-sbc Engine 12 09-15-2009 08:00 PM
What the ***** is wrong with my timing cover/ harmonic balancer!!! sexypizzaman Engine 56 10-28-2008 03:49 AM
Harmonic Balancer Issue newdad1 Engine 12 10-09-2008 03:54 PM
283 Harmonic Balancer JamesD Engine 29 03-14-2007 05:36 PM
sbc 327 vs 350 Harmonic Balancer Question Ted's37 Engine 3 07-14-2003 04:10 PM
