Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Install issues with 7 wire Chieftain turn signal switch...help please
Old 07-12-2012, 06:21 PM
LATECH's Avatar
LATECH LATECH is online now
For a 3 terminal flasher :
Black wire goes to L terminal on flasher
Blue wire goes to P terminal
Hot wire from ignition goes to the X terminal
yellow front left turn
Green front right turn
Brown to right rear turn
Orange to left rear turn
Red wire from turn signal switch goes to brake light switch terminal that is not allways hot
If you are using a 2 pole flasher twist the black and blue together and hook them to the L terminal
Got this over at stovebolt .com
Fact is stranger than Fiction
