Install issues with 7 wire Chieftain turn signal switch...help please
Hey guys I'm attempting to install a 7 wire Chieftain turn signal switch onto a 41 Oldsmobile and I ran into a snag. I ran the red wire to the brake switch wire that is NOT hot all the time and the blue and black wires to the corresponding terminals on my 3 prong flasher. Then I ran the wires for the rear lights using new wire all the way back to just before each of the left and right bulb sockets, splicing them into the sockets there. Now when I try to use either directional both are coming on instead of just one side. I'm guessing I have something hooked up wrong and it's back feeding power back through the circuit and into both bulbs?
Any help is greatly appreciated. Also Is there any way to wire this switch into a single filament front parking bulb and still have the light work as both parking and signal? |
For a 3 terminal flasher :
Black wire goes to L terminal on flasher Blue wire goes to P terminal Hot wire from ignition goes to the X terminal yellow front left turn Green front right turn Brown to right rear turn Orange to left rear turn Red wire from turn signal switch goes to brake light switch terminal that is not allways hot If you are using a 2 pole flasher twist the black and blue together and hook them to the L terminal Got this over at stovebolt .com |
As far as using a single filament on the front for turns and/or parking...no.
You should be able to replace the socket with a dual filament socket, run an extra wire to each and end up with park/turns in the front. |
Also...are you sure the bulbs in question have a good ground?
I have the wiring hooked up as noted and my grounds are good.
Was I right to run my wires all the way back to the sockets? I may be wrong in how they're hooked up. One lead has the parking light feed into it and the other has both the brake and signal feeds going into it. |
Your new wires from the turn signal switch should be the only wires connected to the bright filaments on the stop/turn lamps. You need to eliminate any connections between the stop/turn lamps and the original brake light wiring. On the front lights, converting the existing turn light sockets to accept dual filament bulbs would be the best, most reliable solution, IMO. If you really want to use single filament bulbs for both park and turn lights, it is possible. You could use a trailer light converter like this one to combine the park and front turn light functions. Not sure if it will work if your car is still 6 volt. In either case you still need to run separate wires out to each of the front turn lights. Hope this helps....:thumbup: |
Joe I think you hit my problem right on the head for the rears.....thanks.
I may try the trailer light controller idea on the fronts as well. I run one on my motorcycle...although like you said it may not work off of 6V. |
Ok guys I'm half way there. I removed the stock brake light wiring and kept only the wiring from the turn signal switch attached and everything is operating properly now.....except when I turn on the parking or headlights. Then my signals no longer work. I checked and they are on different filaments so I'm not sure what's causing the issue. Any thoughts?
Oh one other issue as well. The car has fog lights on the front and we decided we would disconnect them from the switch under the dash and wire them in seperately for the front signals instead. However they are much dimmer when hooked up to the turn signal switch than when they are hooked up to the foglight switch. Is the turn signal switch not providing them with enough power? As fog lights they are drawing power straight off of the battery.
If it's not the ground(s), it could be that, for whatever reason, the lamp contacts are not lining up with the socket contacts, like maybe one of the bulbs isn't turned to the fully locked position, or perhaps one of the socket contact discs is not indexed correctly. Quote:
If you converted the fog lights to accept an 1154 bulb, then using them for turn lights would be quite doable. But I would hesitate to do it with the original bulbs. Good luck.....:thumbup: |
| All times are GMT -6. The time now is 03:23 PM. |
