A Jag rear end in an 'A' is tough as that car is so narrow and the rear end so wide at 63-64+/- inches when you need something in the 57-58 inch width to fit under normal fenders or without hanging way out past a fenderless body. Yeah, you can modify it to fit. But correctly? I would suggest that you look at an aftermarket supplier for an engineered kit - for instance Heidt's, tho very expensive($7000+) vs an 8/9 inch Ford for a few hundred
