-   -   Install jag rearend in 1928 model A (http://www.hotrodders.com/forum/install-jag-rearend-1928-model-228365.html)
tudust 01-13-2013 10:20 PM
Trying to install a jag rearend in my 28 model A with a stock frame. Anybody know where I can finds pics or info on this?
Thanks
Terry
327NUT 01-14-2013 12:00 AM
Seen them ,never done one....but there is www.irsforum.com, i'm sure they can help.
Irelands child 01-14-2013 06:45 AM
A Jag rear end in an 'A' is tough as that car is so narrow and the rear end so wide at 63-64+/- inches when you need something in the 57-58 inch width to fit under normal fenders or without hanging way out past a fenderless body. Yeah, you can modify it to fit. But correctly? I would suggest that you look at an aftermarket supplier for an engineered kit - for instance Heidt's, tho very expensive($7000+) vs an 8/9 inch Ford for a few hundred
2old2fast 01-14-2013 07:24 AM
Lotsa T buckets w/ jag rears in 'em... that's a very narrow frame... might check out some T sites for info ..
dave
timothale 01-14-2013 07:43 AM
Jag irs.
The XkE Jag is narrow enough to fit easily but has wire wheels. Kits or sedan pieces can be used for 5 lug chevy wheel patterns. A retired machinist in San Martin, Calif lived just north of Me and built complete Model A chassis using the Jag XkE torsion bar front and the XkE Rear suspensions. It has been about 10 years since I was to California and visited his shop behind his house . Most XKE parts are now expensive too because of restoration demands. Jag sedan rear ends can be narrowed, and new tubular half-drive shafts fabricated. There are various width's of rears used in the sedans. My son had an XJS rear in his 22 dodge lakester. We used the CCR T bucket plans, moved the upper spring-shock mounts inboard as per the plan but it is still a little too stiff for my liking. Google Jag IRS IFS suspension swaps and you will find lots of info K & K custom crosmembers in australia or new Zeland has custom parts to use the Jag sedan front suspension parts.
