Install new fuel line in a 69 Chevelle - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2013, 10:09 AM
ss396si's Avatar
My original fuel line is 5/16 for a 305 small block. I want to upgrade to a 3/8 for a future big block conversion. Will the 305 run the same w/ the 3/8 hard line? Or will it get to much fuel?
Old 01-24-2013, 03:25 PM
bondo's Avatar
Nope,... The fuel pump will supply the induction system with the fuel it needs, 'n no more...
Old 01-24-2013, 04:01 PM
ss396si's Avatar
With that 3/8 line installed for agruements sake would that support a 550hp/tq big block?
Old 01-24-2013, 05:10 PM
vinniekq2's Avatar
I ran 1/2 inch line for my small block.
Why would you even consider less?
Old 01-24-2013, 06:02 PM
ss396si's Avatar
Because 3/8 is a factory original size,Why do you have a 1/2 inch line for a small block?
Old 01-24-2013, 06:08 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
The bigger line won't hurt if you run it on a Small Block... I run 1/2'' on my big block cars even on a hot small block sometimes... I use 3/8'' a lot as well..The pump is only going to take what it needs..
I like the bigger line, Over having to small of a line, that way the pump always has enough fuel..
Old 01-24-2013, 06:16 PM
vinniekq2's Avatar
The 1/2 inch line is close to the same cost.I need to move a fair amount of fuel to the engine and needed an upgrade over stock. Your car needs over 200 pounds of fuel per hour delivered to your engine to feed your 550 horses
Old 01-24-2013, 07:33 PM
I use -8 an stainless steel braided line from the tank to the regulator in the engine compartment. This is on a big block 67 Camaro. The kit came with a 20 ft. roll of fuel line with all the fittings. You can use this 1/2 aluminum tubing without investing a fortune in a new fuel line. Summit Racing® Aluminum Fuel Lines SUM-G2512 - SummitRacing.com
The Following User Says Thank You to cdminter59 For This Useful Post:
vinniekq2 (01-24-2013)
Fuel line kit for Holley 4150 and stock fuel pump colin911 Engine 4 09-13-2011 08:24 PM
Line lock install red_rider52 Suspension - Brakes - Steering 5 05-07-2007 05:01 PM
Copper Brake Line,Fuel Line redlightning General Rodding Tech 6 08-23-2006 08:50 PM
FUEL LINE & TRANS LINE SIZE/TYPE leejoy Hotrodding Basics 7 11-29-2005 10:59 PM
Chevelle Fuel line question heavychevy Engine 1 04-01-2003 10:39 PM
