Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - installation of wilwood rear disc brakes on 9 in. ford
Old 03-16-2013, 03:48 PM
wheel-7 wheel-7 is offline
I have a couple of questions concerning Wilwood rear disc brakes on a Ford 9 in. rear that I hope I get someone could help me with.
1. On the " U " shaped calipher mounting bracket there is about a 1/8 recess machined into the bracket on one side( follows the contour of the axel) . On the other side flat and smooth. Is the recess side of the bracket mounted toward the center section or towards the wheel ?
2. I have a " full circle axel retainer " The retainer is really oblong but they called it a full circle retainer. Does the " U " shaped calipher bracket fit over the axel retainer or under it ? In other words, do you mount the " U " shaped calipher bracket on first then put the axel retainer on or vice versa ?
Any help would greatly be appreciated..I checked the Wilwood web site but they didnt go into that kind of detail.
This maybe to much to ask but pictures of diagrams would help a lot.
Thanks
